Displays general loading sharing information.
port | View load sharing information for a specific port. |
port_number | View load sharing information for a specific port. |
detail | Show details for the specified ports in the load sharing group. |
N/A.
The following example shows load sharing information for the switch:
# show sharing show sharing Load Sharing Monitor Config Current Agg Min Ld Share Dist Ld Share Agg Link Link Up Master Master Control Active Algorithm Flags Group Mbr State Transitions ================================================================================ 1:91 1:91 Static 1 L3_L4 A 1:91 Y A 1 ================================================================================ Link State: A-Active, D-Disabled, R-Ready, NP-Port not present, L-Loopback Minimum Active: (<) Group is down. # active links less than configured minimum Load Sharing Algorithm: (L2) Layer 2 address based, (L3) Layer 3 address based (L3_L4) Layer 3 address and Layer 4 port based (custom) User-selected address-based configuration Custom Algorithm Configuration: ipv4 L3-and-L4, xor Custom Hash Seed: Switch MAC address (0x969C3CE2) Distribution Flags: A - All: Distribute to all members, L - Local Slot: Distribute to members local to ingress slot, P - Port Lists: Distribute to per-slot configurable subset of members, R - Resilient Hashing enabled. Number of load sharing trunks: 1
This command was first available in ExtremeXOS 11.0.
Custom hash seed information was added in ExtremeXOS 30.1.
